1994 454 XL Part numbers?
Saltshaker
Hi I'm looking to confirm rw impeller kits and alternator / raw water belt models. These are for spare belts to have on board. The impellers i plan to replace before the season. Local marine store says he has the impeller kits in stock and theyre pretty standard. I can see the alternator belt has 98210 stamped on it.
Thanks!
my listing shows that alternator belt number...raw water pump belt shows 10258, impeller is 20300 and the gasket is 40059. The kit is probably OEM from the pump supplier and may have a different crusader number...10615K is what the sherwood flyer shows
thank you mako mark, i called they do have the sherwood numbers but dont stock belts. he said he gets his belts at napa, think thats ok? i think the belts look good so more for spares.
thanks!
