1994 40 hp 4 cyl 2 stroke
jimsrtc
After replacing the water pump impeller it will not pick up water. It's the first time I have attempted this. All I replaced was the impeller. Everything seemed to go back together correctly. So what did I screw up?
You might want to pull the LU off again (ugh!) and bucket test it. Spin the driveshaft with a drill and look for water shooting up. If no, then start investigating.
Jeff
PS: Here's how to spin the driveshaft. The drill adapters are sold by Harbor Freight and elsewhere.
Did you make sure the water tube went into the impeller housing when you slid the lower unit back on. It doesn't always fit together on its own. By the way that motor is awesome! One of the best Mercury ever made in my opinion.
