1994 225 Evinrude Ocean Pro Missing badly - I did the Ohm test on each coil they all tested good. Not satisfied with that, I started the engine and pulled the corresponding ignition wire off each spark plug one at a time. All are getting good spark except cylinder No.2 (top port side). Then I switched the coil with another cylinder it works fine in other location, plenty of spark, but cylinder No.2 is still not getting any spark.
I also made the following observations which might or mightnot be related:
1. The tack is registering RPM's.
2. When cold starting the engine does something like a hick-up and stops cranking. It does this a number of times before it actualy starts.
3. While running now with a miss it does something like acough about every 5 seconds.
Any help is appreciated, thanks.
