1994 150 Timing How do you set it
ericv
"1994 Evinrude 60deg 150, the
"1994 Evinrude 60deg 150, the manual says to use an omc tool to set the timing. Can it be done manually with a timing light as well? Are there specific things that need to be done to do this, is this a dealer only adjustment?"
"You shouldn't have any pr
"You shouldn't have any problem if you use a timing light, it basically does the same thing. On a car you do it on the pulley system. On a boat its done directly on the flywheel on top of the motor. Just go with what your manual says that motor should be. Hope that helps."
The more i think about it newe
The more i think about it newer engines may not be able to use the timing light because 60 deg seems a little much. I have an '82 johnson 70 hp and it only has like 19.2 deg or something like that.
