90 johnson vj90tlets. i took lower unit off to reseal and replace water pump complete kit. i ordered my parts first. a lower unit reseal kit. water pump assembly. looking at the parts diagram it shows a shift rod spacer. i ordered the spacer also. once i took the lower unit off the engine i don't see where the spacer goes unless it's just missing.
it's #10 in the diagram. it shows it is in between the housing and the shaft seal. when i took mine apart i only had the shift housing with the seal directly on top. thanks. first time posting but i have used the sight many times so thanks,
