Finally got parts -rebuilt all carbs- replaced throttle body gaskets- intake gaskets- reed leafs on #5 and#3 cylinder torqued to proper specs etc. engine runs great no spitting out carbs -Just wanted to let you guys know how much you helped me------ tremendously!.Special thanks to -Daselbee---Fastbullet---and joereeves-you guys know your motors well Thanks again.-Now I have a new problem ---the vro -can it pump gas and not pump oil-because the gas works great but the oil isn't pumping ,should I replace the pulse limiter?Not a clue on this one . I know how to bypass the oil pump but I would really like to figure out why it dosent work-Any thoughts
