I just bought a used 18' f
I just bought a used 18' flats boat it has a 93 evinrude 115 it was supposed to run perfect the guy i bought it from was the orignal owner and seem to tell the truth. I thought. The problem is the motor will not go wot and wont get up past 2000 rpm in drive. I started trouble shooting and found the compression was high and even and i removed the vro cause i was told it gave him problems before. And would cause the boat to enter slow mode. I checked the spark and all was good except one plug wire was jumping but still getting spark. The primer bulb is always full and i replaced some of the fuel hose at the back of the boat. I put Sea Foam in the motor today and it didnt help. Any suggestions? the water coming out the pee hole supposed to be cold all the time? the motor runs great it idles fine it revs up without sputtering backfireing. Just wont get up and go.
