K
Kevin McKee
Guest
"I was installing a new impell
"I was installing a new impeller and seals (the seals were bad, leaking water into lower unit). When I removed the black plastic "retainer" that holds the shift shaft in place, the shaft came up and out with the retainer. I did put it in FORWARD before I removed the lower unit. Now, when I install the shift shaft it just spins freely, it will not shift out of forward. PLEASE HELP!! My maintenance book does not touch at all on this problem"
