"I have a 93' 70Hp Johnson
"I have a 93' 70Hp Johnson O/B. Took off the head and #1 ring is broke and peppered the head pretty bad. Noticed that #2 and #3 had 110 lbs compression cold. Is this right. Also noticed #2 and #3 pistons are stamped .030. #1 looks like factory 1992 date stamp. I am assuming several things, first, this has been rebuilt before, #2and #3 are .30 over, and #1 is OEM. Question, can I get a peppered head repaired or does it need to be replaced, and can I get #1 bored .30 0ver and just replace the piston. Thank you, Mike."
