Built in tank? Vent hose clogged?
6 gal.? vent open?
Squeezie has a one way valve that can go bad?
Does the squeezie get hard when you pump it up?
Yes? then the pump is probably good, rebuild it anyway(just in case).
No? then the diaphragm is possibly bad,rebuild it anyway.
The carb, the needle/ seat is sticking, clean carb.
The hoses, they can delaminate / melt. They turn soft and mushy and collapse when the pump draws fuel.
The inline connectors, they have rubber in them and it can go bad allowing it to suck air, replace or remove.
Possibly overheating?? test the overheat system.
I use a temp gun.$20 amazon/ .
Test: key on, ground the orange lead at the buss bar.
It should sound off.
There might be more but this should keep you busy for a while
Do the last thing first!
