M
Mark Johnson
Guest
"1st time a dealer found prima
"1st time a dealer found primary wire pinched. rerouting fixed problem. 2nd time, I found a wire with worn sheilding leading from the terminal block to under the flywheel. Black tape fixed problem. I now have no spark again. Tried new plugs, Bypassing the emergency shut off switch. I suspect another short. Can anyone help me with how I might troubleshoot the problem. Is there an easy way to determine if the switch is bad, or if any of the other electrical components are bad? I have access to a multimeter."
