1993 150 hp johnson firing problem
tomtran66
have problem with my 1993 150
have problem with my 1993 150 hp fast strike Johnson. 5 out of 6 cylinder are fire. I check the coil and they are runing fine. There is not power to the coil for cylinder #2. I also measure the voltage from the power pack and 4 of the cylinder produce in 60 volts and 2 other cylinder produce only 8 volts. Would you please give me some suggestion. Please let me know if 6 wires from the right hand side of power looking from the back are power supply to or from Powerpack? Your helps is greatly appreciated.
