1993 120 Johnson
doug_k
"I just bought a 120 and start
"I just bought a 120 and started it with the hose it pees continuously but not real strong and the water is hot to the touch. I took off the coul and the heads are hot to the touch, Is this normal? Thanks"
"Should be able to touch both
"Should be able to touch both heads with bare fingers, and not get burned...If it gets so hot that you cant touch either head, and/or there is steam coming out..might be time to replace the water pump.."
