I have a 92 Suzuki dt30 that will start and run beautifully in a test barrel. When I put it in the lake it runs well until I go to throttle down on it, it dogs out and will die about 95% of the time. I have replaced the fuel pump, the filter assembly, fuel tank, primer bulb, had all three carbs rebuilt, I changed fuel hose from 1/4" id to 5/16" id from the tank to the filter. From the filter to the carbs it is new 1/4" id line. If someone else has had this problem or has any suggestions to fix the problem please let me know.
Thanks,
Steve
Thanks,
Steve
