1992 Suzuki dt 150 rough idle
ocean
"1992 suzuki dt150 was running
"1992 suzuki dt150 was running fine, and now rough and stalling idle. sometimes seems to backfire or miss. No real indicators before the change. above 1200 rpm still runs strong, cruises fine. Any thoughts? It has new plugs already ( changed after problem started)."
What is the estimated time to
What is the estimated time to have a mechanic clean the jets? Would running Sea Foam through it potentially do it?
Thank you
"If compression and spark is o
"If compression and spark is okay, clean carbs. Check with dealership on cost."
