I have a 1992 Mercury 115 hp 4 cyl. and my tachometer isn't working. I've read that a bad rectifier can cause that issue. I have tried to locate the rectifier but can't find it. All that I can find is the terminal block. I'm not sure if my motor even has a rectifier. I have searched the net and see sites that call the terminal block a rectifier assembly. I seen the parts diagram for a three cyl. 90 hp and it didn't have a rectifier as far s I could tell. Does my motor have a rectifier or dose it use a terminal block? My terminal block has 3 yellow wires one on the top post and on the bottom post. There are 2 gray wires going to the middle post that says tach.
