Hey Guys, I'm new to the forum and new to this boat/motor. I have done a lot of work
n smaller motors/carbs but not sure where to start with this one. I just bought the boat, it starts and runs pretty decent. A little rough at idle when cold, but once warmed up everything seems to run pretty decent. If I turn the motor off when it is hot it does not want to restart unless I give it a ton of throttle and then it revs to the moon and when I pull it back it usually dies. I have to find the right combination to keep it running, after that it seems fine again. Apparently the previous owner tried rebuilding the carb a couple of times then told me he sent it off and they sent him a replacement, but it wasn't the original but was supposed to work with this motor. I suspect I'm fighting a carb problem. This motor has the individual coil packs and I've gone through and replaced the spark plugs already. My biggest concern at the moment is identifying the carb and why some nipples are capped and some are not. It also looks like a ground cable for the choke is not connected (see attached pic). Any thoughts on what these items are and where I should start? Thanks in advance!
