"Hi, This is an Impressive dis
"Hi, This is an Impressive discussion group. Hope you can give me some help with my problem? Bear with me as my description of problem may be a bit drawn out.I apologise in advance.
I have a 1992 Stingray 537zp with a 3 litre Merc.
Engine starts and idles/revs fine on the drive with muffs connected. Drop it in the water & motor out into the bay and open her up (3000 - 4000 revs)and climbs quickly on to the plane for about 2 minutes then dies on me. First time this happened i could not start her back up. Had to be towed back to slipway.Suspected Fuel as i have spark.
Removed filters at pump and carb and cleaned.Some gunk present but seemed lack of fuel at carb inlet. Replaced fuel pump over winter and winterised boat inc fuel stabiliser. This season Fired up on the drive with outdrive in tank of water ran fine. Dropped her in the water and motored out(speed limit)into the bay and opened up. She went beautifully for about a few minutes and then lost power on me again. But this time i throtttled back and she will run at 1000 revs 5-10 knots. but repeats the process again when i get up on the plane. Still suspect carb/fuel problem.
i have carb dismantled at home and looking at pump plunger inside. Manual says invert and catch Ball from under plunger. Mine did not have a ball.
It is a good 2 hour drive to my cruising grounds so Any suggestions / help would be most welcome & appreciated.
Regards
Rod F"
Regards
Rod F"
