"I have a 1992 VJ150GLENC John
"I have a 1992 VJ150GLENC Johnson outboard motor. The tilt motor is not working. I believe the relays are working because when I press the up or down button, I hear a small "click" noise. That also makes me believe it has power. Any suggestions of where to start. Also, I just had the tilt motor replaced by a shop about 1.5 to 2 years ago.(For the sum of $1000.00) Would like to avoid that charge again.
Seperate issue...I notice when I run this motor I get a lot of cavitation. Any suggestions on how to fix/correct position of motor. The motor is equipped with the whale tail skags. Could that be the problem?
Steve"
Steve"
