I have a 1992 Johnson Nitro 150hp. I bought the boat used and the first time I took it out in started getting a constant alarm warning. I'm new to boats so I didn't know what was. I unplugged the buzzer because it was driving me nuts. Ok. Not knowing it was an overheating warning now it's not sounding. The boat would run fine for a min and then bogg down like it wasn't getting fuel so I assumed it was a fuel issue. I noticed that my primer bulb was going flat and not hard so I changed it. I also made sure everything else was flowing good as far as the fuel. I ran it off a spare gas tank and line from a John boat and it still stalled and cut off. Run great for a min then crap out. All of a sudden run great again and than die at full throttle. So now my focus went from gas to overheating. Also let me mention that I mix the oil myself. I think the pump was bypassed. I just pulled the bottom end off and changed the empeller and water pump. Now knowing that the buzzer was a warning I plugged it back up. Took it out today for the first time since the new water pump kit and it ran fine for a minute then it bogged down again with a constant alarm warning. Could it be a bad sensor or something? Would that cause it to run like crap and then be fine again? When the alarm goes off the motor is still pretty much cool to the touch. I'm about to just buy a Mercury. Please if you can help I would really appreciate it. Thanks.
