I have a 1992 15 hp Johnson 15RELENM. A part has broken off just below the flywheel. The piece that broke off is black plastic and has a screw in the end. I appears that the screw pushed the cam surface slightly away. The part interfaces with a cam roller attached via a lever to the carb top plate. In the ignition parts illustration for this motor the only thing that slightly resembles the broken part is part 0396740, cam and screw assembly. It however appears to be metal and the shape is not the same.
Anyone help me with identifying the correct part?
bob
bob
