[email protected]
After 3 weeks of not using my boat I go to run it before a planned fishing trip. Well before trying to get it to crank I remounted my ignition switch to the center console. After a few minutes of attempting to crank it, it would not crank. Primer injector was working. And I was getting fuel to the carbs. After letting completely off the advance throttle and having it in neutral the motor cranked up like it never missed a beat, this is after at least 45 minutes of me trying to get it to crank. I didn't have it on the muffs at that time so I only let run for maybe 10 seconds. Everything seemed fine. Went to crank it again and once again nothing and still to this day nothing. Heres a little history it's a 1992 Johnson 120 vj120tlend. Vro removed. I replaced the power pack, coils, plugs, and wires at the first of the year. I don't know if when I remounted the ignition if I pulled the kill switch wire loose or what but it's not firing on any cylinders but will turn over all day long. Any help would be greatly appreciated. Thanks.
