D
David Nix
Guest
" I removed the lower unit on
" I removed the lower unit on my 1992 150 Evinrude to replace the impeller. It was worn out and had some sand in it. While I had it apart I check the lube oil and a little water dripped out of the bottom plug so I drained it all out. I took off the prop and there was a ton of fishing line behind it. I want to go ahead and replace the seal on the prop shaft and on the top of the lower unit under the impeller. Is this something I can do? I have replaced seals in wheel hubs and such by prying them out but I don't want to mess up the housing. Do you have to have special tools? If I take it to the local OMC dealer will they charge me an arm and a leg to replace the seals since I already have it apart. Also, the shaft sticking out of the lower unit that goes to the engine has a little side to side wiggle in it. Is this normal? I also noticed that the little plastic screen on the water intake below the impeller is missing some of the "grids" where the holes are on the sides. How do I replace that and what is it called?
One last thing. When I tilt the motor up all the way and it sits for a little while I get oily looking stuff leaking out of the round air intake holes and dripping into the back of the boat. Not much, just enough to make a mess. Is this normal?
Thanks in advance.
David Nix "
Thanks in advance.
David Nix "
