1992 e225tx
tlittle
"hello people,terry here,could
"hello people,terry here,could anybody email me wiring diagram for ing switch 6 prong. if i dis-connect wiring harness at motor and bump starter runs like top re-connect dies.i may have switch wired wrong!!!will start from ing switch but only last 10sec or so and dies.email is [email protected]"
"The six terminals on the back
"The six terminals on the back of that ignition switch are usually marked: B, C, M, S, A, M, but not necessarily in that order.
If so, what color are the wires that are normally attached to that switch?"
mag tree- blk yellow stripe
mag tree- blk yellow stripe b-red/blue stripe mag prog-3blk a-2 purple c-purple/wht stripe s-blk wire may have been changed by prev owner is how its wired now
"David.... Great diagram.
T
Terry, as per David's diagram, and depending on the actual color of the wire (listing both colors here).........
M - Black/Yellow (Kill circuit)
B - Red/Violet or Red/Blue (Bat voltage)
M - Black (ground)
A - Purple (Voltage to accessories)
C - Purple/White or Violet/White (Choke/Primer solenoid
S - White or Yellow/Red (To starter solenoid)
That black wire you say is attached to the "S" terminal of the ignition switch..... trace it to see if it leads to one of the small 3/8" nuts on the starter solenoid. That's where the "S" terminal should lead to.
Check the small wires leading from the large battery terminal of the starter solenoid for the power fuse to see if it might have been blown."
