1992 70hp johnson
Curt O
On the power trim and tilt relays, are they just a plug in and out ? I have one that is going bad and i tried to unplug it but it seemed pretty tight and i didn't want to use too much force. Thanks
If you're speaking of the wire(s) that lead from the PTT switch, yes, that wiring harness leads to a nylon plug connector which simply pulls apart. It's a tight fit to keep weather out but corrosion does find its way in there. Possibly all that's needed is to clean the contacts within that plug.
The relays in the box are quite tight ---The contacts are coated with a corrosion preventing compound.---------------They will pull out with some effort.
Misread your post, sorry. Skipped right over that relay mention for some reason. As you've found, obviously they're just tight.
