daunderwood
1992 3.0 stumbling under load
I have a 1992 3.0 four cylinder Mercruiser that has always been quite reliable. Until last summer, that is. One day it began really struggling when pulling a tube. The engine will run up to nearly 5000 rpm with several people in the boat with no trouble, but once I put something in the water to pull I can't get much over 3000 rpm before the engine begins stumbling, losing power, and backfiring.
I've checked the inline filter and have replaced the fuel line from the mechanical pump to the carbuerator (on the advice of a mechanic friend who thought I might be pulling in air through an old cracked fuel line) but I still have the same symptoms. The only change I've made was to replace the spark plugs last year. I gapped them a couple of hundredths too wide - something I didn't find out until I'd replaced them all. Could a too-wide gap cause the trouble under load that I'm experiencing, or does anyone have an idea of some other way I should go?
Thanks in adavance,
David
Thanks in adavance,
David
