REVISED... I need help" I have a 1991 Mercury 150hp v6 Black max W/Brand new Power head from Mercury... I completed the swap on the power head... In the water the motor had no power it would run at idle and if I manually throttled up it would race this is what I tried... I replaced the voltage reg and the alarm box, I was having an issue with no spark on the left 3 cylinders, the right side is operating perfectly.
I then replaced the ... stator & the Switch box for the left side... Now I have to much spark on the left side... I then tested the trigger... tested good... it now sparks 2 to 3 times more then it should ? What is up with that?
Thank you for any reply
