So I'm finally getting to the point where I can put my new to me starcraft 19' deep V with a 1991 Johnson V4 in the water. Because it s new to me I wanted to start it out of the water first using a flushing device (earmuff). The motor started fine however there was no water being ejected at the top of the engine. I immediately turned the engine off and let the water runnng through the flushing device. I did see a stream of water coming from a small hole behind the intake grill and what I think was another stream from behind the engine and a little hogher than the intakes.
My immediate thought was oh %$^%(@ - wat I have got myself into now. Then I pulled out my spanking new service manual and did some reading. I did find a section where it was noted that the powerhead has thermostats that prevent water from flowing into the powerhead until it comes up to operating temperature. I also saw that there was some discussion about a pressure relief valve.
So I'm wondering how long it would take for the thermostat to open up and allow cooling water into the powerhead and out of the ejection tube? Secondly, are the streams of water I see from holes in the lower unit because of a bypass/pressure releif until the powerhead thermostats engage.
Rick
Rick
