1991 Johnson 40hp Outboard Motor
Troysboat
Trim isn't working properly. It will trim up but not down. The motor doesn't even make a noise when pushing the trim button down, but it does when trimming up. Is there a way to manually trim up/down? Any suggestions on what it may be to get trim down to function again?
On the drivers side of the boat/engine (starboard) towards the back there is a panel about the size of your hand. Remove that cover & two relays are in there. They are square 1" devices. Swap places with both & see if motor will go down. I suggest changing both relays if that fixes the problem.
