In other words.....HELP!!!!!
Here's a good one! I've got a 91 Johnson 40 that has a start problem..... We'll start off by stating that someone had taken the keyswitch out of the control box to mount it in the center console.... So I made that right by reinstalling the keyswitch in it's proper location, and changing the switch as it looked like someone held onto the body of the switch with a pair of channel locks. No start. Double checked the wire positions, still no start. Check battery voltage, reads good at 13.6 volts. Clean the connections, and make sure they're tight. Still no start. See that someone had hacked into the wiring harness from the switch to the motor, so I swapped it out with a NOS one. Still no start. Check for voltage back at the solenoid to see if it was getting voltage back through the system. CHECK! Go through the entire check list as per the OMC manual for that motor, and EVERYTHING checks out until you get to number 7 on the check list. I get 2.3 volts at the starter, the solenoid sounds like it's going to hop apart because it's trying to get voltage to the starter, but can't (rat ta tatatatatatatatatatatatat. You get the idea.) So I figure the starter wasn't grounding, so I pull it off, clean the connections on the block and starter mounts, and reinstall the starter. Still nothing! Take the starter cable off the solenoid and test for voltage. Solenoid is operational, and getting 13.5 volts at the starter cable ring terminal that mounts to the starter motor lug. So I open the starter up. Magnets inside are cracked. OK, buy a new starter. Install new starter. NOTHING! Solenoid still sounds like it's going to rattle apart. So I swap out the solenoid to starter cable. Still doing the SAME THING! I've cleaned every connection on this motor, on the battery and cables, checked the keyswitch as per the manual, even went as far as swapping out control boxes thinking there was something funky with the harness. STILL NOTHING! The replacement starter motor will operate on the ground with one wire grounding the case, and the other going to the battery, but once you bolt it to the motor, it's got nothing. Everything checks out until you bolt the starter to the powerhead, and hook the battery cable up from the solenoid to the starter. I've even swapped wires around on the solenoid thinking that might make a difference. STILL NOTHING except the solenoid sounding like it's going to rattle apart.
I'm really scratching my head over this, and wonder where to go from here, because I'm out of thoughts.
Any ideas? Anyone, anyone? Bueller, Bueller?
Ripper
Ripper
