Hey guys, new to the forum. Unfortunately i was kind of forced here because i am stumped on my engine i just now bought.
My 1991 Johnson 40 hp 2-stroke will not run past 2000 rpm. It starts up, idles, & even cruises great up until just before half throttle and bogs down. However, if i push the Key in activating the electric Primer it will plane the boat and run perfectly at full throttle, but will bog right down the second i stop pushing the key and the problem remains.
The one thing i have personally noticed when looking inside the Carb Bores is that the Bottom Carb is barely shooting any gas into the manifold compared to top Carb at full throttle
Here is everything i have done to it up to this very point:
Tested Compression: 120 psi Top Cylinder & 125 psi Bottom Cylinder
Replaced the Floats
Cleaned all the jets thoroughly including the Main jets with a steel wire and soaked everything in Carb Cleaner.
New Fuel, Premium unleaded
New Sparkplugs
Could it possibly need new Reeds?
I will keep you guys all posted until the motor is running. I want to get into the ocean for some halibut before winter comes. So please help.
Replaced the Floats
New Sparkplugs
