1991 Johnson 115hp
pocket
"When the motor is at idle or
"When the motor is at idle or very low rpms it misses badly, it sounds like an electrical problem because of the short miss, but sometimes when I press in the choke it helps out. It does it more frequently when it’s cold but also when it’s warmed up. Once the rpms are above 1500 - 2000 it runs fine. I greatly appreciate any information you can help me with. Thanks"
"sounds like u r running lean,
"sounds like u r running lean,at idle...ck,sprk-compression,and that all plastic throttle rlrs r in place,not necc ur immediate prob,but a prob...if all ok,...i'd clean/rebuild the carbs for sure..inst new plugs...ck linkage and synchronization,adjustments,and ck eng temp,on both hds,at idle.....but i think,u have an idle restriction."
