In Canada try----evinrudeparts.ca----See if they can help.
The latest water pump kit has the instructions for drilling.----And yes the instructions say that you can use the old port for a pressure gauge.
What does the insulation look like inside the cowling?
Congratulations Racer for your 20,000 posts I don't think anyone here will ever last that long.
You have a carburetor or reed valve issue.
If the carb is spitting fuel back at you, it would indicate that crankcase pressurization on the downstroke of the piston is pushing the air/fuel mixture past the reeds instead of containing the air/fuel charge so it can reach the combustion chamber for the next power stroke. If the carbs haven't been off in a few years, it's probably better to pull them off anyways so you can dismantle them and clean up everything to inspect all the components. At which time you'll be able to inspect the reeds as well. I learned about how vitally important carburetor function is on two-stroke engines when going through the ensuing saga of repairing my '64 Evinrude 9.5 Sportwin. This forum was a great help for getting it running right!Can I take the carb off and if a visual inspection doesn't show anything in the reeds, try to turn it over a few seconds (fuel line disconnected) and see if the reeds move at all? Just so I know if that's the issue before stripping everything down?
If the carb is spitting fuel back at you, it would indicate that crankcase pressurization on the downstroke of the piston is pushing the air/fuel mixture past the reeds instead of containing the air/fuel charge so it can reach the combustion chamber for the next power stroke. If the carbs haven't been off in a few years, it's probably better to pull them off anyways so you can dismantle them and clean up everything to inspect all the components. At which time you'll be able to inspect the reeds as well. I learned about how vitally important carburetor function is on two-stroke engines when going through the ensuing saga of repairing my '64 Evinrude 9.5 Sportwin. This forum was a great help for getting it running right!![]()
Right. Reeds rarely break and of one is stuck open with some debris, it will certainly create noticable distinction of associated cylinder and carb. If you post a video link we can study the action with air box removed...we can hear and see but not touch......kinda like a stripper at the club, but being JW, I don't do that anymore.
