Joe I looked at you listings. Do you have stators for my engine?
Had a local marine repair shop let me try the stator, timing base and power pack. did one at a time, final results was the power pack.
Isn't this the same as plugging a remote key switch into red harness connector on engine? This would eliminate original ignition and kill swith at drivers postion - correct. I have the same problem on a boat I am working on. Starts right up and then another day it won't. Have a spark plug gap testor, no spark and then fool around a little more spark comes back and motor fires. All spark was gone then come back abd warms up runs great. Hard to image bad stator or trigger would run that well once running??At the engine... disconnect the Black/Yellow wire from the powerpack that leads to the ignition switch and kill switch. If you now have spark, there is intermittent short in either the ignition switch or the wiring harness leading from the engine to the ignition switch.
To determine which.... connect that Black/Yellow wire back to the powerpack, then disconnect the Black/Yellow wire from the ignition switch and kill switch.
If no spark... the short is in the wiring harness (somewhere).
If spark exists... the ignition switch is shorted, possibly the kill switch.
I am having the same exact problem on a boat I am repairing right now. No way is it the starter or slow cranking because when it starts it fires right up and runs great. I find it hard to believe stator or trigger are bad as it runs to smooth when running. Was thinking flaky CDI unit. Glad to hear you got a fix. JimMy problem was the power pack. Had a local marine repair shop let me try the stator, timing base and power pack. did one at a time, final results was the power pack. Got a new cdi power pack with the rev limiter, runs great time to go fishing and the stripers will be here soon. I want to thank all who gave me advise with my problem.
