1991 60hp Johnson Fuel Pump Install
renvette
Anyone know where each line goes for the following fuel pump: 438559
Top brass goes to carbs, bottom (pulse) goes to crank case pulse.
You may simply test like this:
Blow into the top (plastic) - it should come out small (middle) brass. Fuel comes in and out again.
Blow in the small (middle) brass - blocked) suck and ok.
Bottom (puls)- you can not suck or blow.
