I find myself trying to help out a co-worker. He has a Mercury 60 hp ( s/n od 161933 ) He thinks it is a '91 or '92.
The problem he is having is that the overheat buzzer ( a constant buzzer) goes off while running. It is peeing good and always has and the head is just warm to the touch.
A little history on what he has done...
Last year he had a mechanic look at it and he replaced the oil bottle and replaced the water pump. I told him that there was no way the oil bottle was making the overheat buzzer go off but he had him replace it any way.
No buzzer till about 20 min on the water then OH buzzer and now after it runs about 3 or 4 min the OH buzzer comes back on. So he disconnected it.
About 2 weeks ago I had him run the motor with the muffs on it and when the buzzer goes off unhook the temp sensor and see it the buzzer stops. The buzzer did not stop, telling me that the temp sensor isn't the problem.
Last week he took it to another mechanic and he said that these motors had a problem with the buzzer itself and replaced the buzzer in the shifter control unit. Well he took it out on the lake yesterday and the buzzer is still going off.
Doesn't these things have a control module?
If so, where will I find it?
Is there a way to check the module?
Any other suggestions would be greatly appreciated. This guy has spent about $600 trying to fix this problem and I hate to see him waste any more money on this. The good thing is that there isn't much more left to replace.
