1991 60 hp 3 cyl overcharging te60tleib
K
karlow
Guest
"Is there an optional voltage
"Is there an optional voltage regulator that I can use to solve my over-charging problem? It reached 18Vdc on the lake last week, & I did not run it that far. How about a regulator from a Merc, or Yami? The battery is new grp 27, and is not a maintenance free type.
KP"
"I would def replace the recti
"I would def replace the rectifier on it..i have seen even 'good' ones,do strange things.."
"As original that engine does
"As original that engine does not have a regulator, just as simple diode rectifier.
I would have installed 0505001 regulator that came as standard later to avoid that kind of problems.(ref BRP catalog 2000/70 hp)"
