Ok well boat ran fine when I bought it. approx a year ago. had some cutting out at high rpm I replaced plugs wires dist cap rotor,
all seemed to help , and at times boat ran perfectly. other times would act up a little at the end of the day,
then started cutting out more,
I went to Tahoe which is at 6500 feet, and boat ran worse, then would not run. I know alltitude can affect performance
then back home
startd boat in driveway adjusted the timeing at someones recomendation, ran fine . took to lake ran for approx 1/2 hour,
but as soon as we tried to pull a wakeboarder. it died , and would't start.
couple times since it would start in driveway, then die after a minute or so. then just turn over , but not fire.
i even tried starting fluid, . no help. soo seems liike some sort of intermittent ignition issue .
possibly coil ? or igg., module
thanks for your help
mike
