Mercury SN 0D03288... I am just getting this motor back up after an ignition failure last fall. Stator and switchbox. The new CDI stator is incompatible with the stock rectifier and needs a regulator/rectifier. The mercury reg/rec is a 5 wire unit, with 2 red wires. I have a new Sierra reg/rec with 4 wires(1 red wire) from a 1991 Force 70 hp that I retired. The Force uses the same stator, but the earlier Mercury 3 cyl switchbox with the ring type terminals. My question is...Is there any reason that I can not or should not use the 4 wire reg/rec on the Merc, just connected like the Force. Thanks, JE
