Re: 91 200hp ve200sleid erratic spark
Here is the pinout functions of the rubber timer base to powerpack plugs. Only applies to 90s era V6 loopers.
On the starboard rubber connector you have:
A: Blue wire, signal to PP for #1 cylinder.
B: Purple wire, signal to PP for #3 cylinder.
C: Green wire, signal to PP for #5 cylinder.
On the port rubber connector you have:
A: Blue wire, signal to PP for #2 cylinder.
B: Purple wire, signal to PP for #4 cylinder.
C: Green wire, signal to PP for #6 cylinder.
The "D" terminals in each rubber boot are white and black/white wires. The black/white wire supplies 6-12 volts FROM the powerpack TO the timer base, and the white wire is the return to ground for the timer base. Ground for the timer base is provided through the powerpack.
EDITED to add information:
The starboard "D" terminal has the black/white stripe wire, and the port "D" terminal has the white wire.
So, for instance, if you have no spark on #4, you might consider debugging on the port side timer base plug, the purple wire, "B" labelled terminal.
I had one terminal pushing back when mating the two plugs, killing the spark on one cylinder, so I did the work to identify each wire for future use/problems.
I hope this helps someone.
