1991 200hp johnson will not start
"the engine turn over good, bu
"the engine turn over good, but will not start, i pulled a sparkplug and placed it on a metal bolt, turned the engine over, but there was no fire. at first i thought it was just a cold start because before when it finally started it would continue to start, but after it sits for two days or so, it is hard to get started again. please any ideas would be a great help"
"See if your safety lanyard is
"See if your safety lanyard is still connected. If so, a shorted keyswitch, or wiring issue can cause same problem. Try disconnecting the large harness plug under the hood. Jump the engine directly from a 12v source using jumper cables. If you now have fire, you definitely have a switch or wiring issue."
