jessielsmall
"i have checked grounds, chang
"i have checked grounds, changed ignition because when i did get it started i couuldnt turn it off with the key. lanyard switch at first would not stop motor at first until i connected the wires right. after this the engine started right up. waited two days tried it again and same problem, no fire. battery is reading at 11.8 volts is this two low to start the engine. any suggestions please help"
