terry_quan
Hello,
Have a '91 200 HP Johnson and having problem with turning it off. Motor starts fine, but when you turn the key off it seems to be running on half the engine. If you turn the key back to "on" the rest of the cylinders turn back on. At first I thought it was the switch, but tested it and the manual was saying bad power pack.
I replaced the power pack this morning and still getting the same problem. Turning the key off or pulling the safety kill seems to drop only half the motor (the left side). With the key off and the motor running on 3 cylinders touching the blk/yel to ground does kill the motor.
Could it still be a bad ignition switch?
Any help would be great.
thanks,
-Terry
thanks,
-Terry
