1991 115 hp johnson
jwbeez
Motor has been running fine th
Motor has been running fine then all of a sudden the motor will have miss for a while then back to running fine does only once in a while any one that can help please do
"Check the spark plugs for a d
"Check the spark plugs for a difference in the appearance of the electrode end. A slight spray of water may be finding its way up thru the air intake area.
Also, check to see if water may be obtaining access to the outer spark plug area of the powerhead. (It happens)"
