wetvette92
"Ok, I have been battleing thi
"Ok, I have been battleing this problem for over a year now. The boat will run fine out of the water and idleing around the boat ramp but as soon as we head out of the no wake zone at crusing speed we will go maybe 1/8 mile and the boat starts cutting out and will die, it won't start again for awhile and will eventually start but repeats and progressively gets worse and ends up not running at all. Now heres what I've replaced related or not: coil, ballast resistor, points, condensor,rotor, starter, solenoid, ignition switch, altenator, impellar, battery. Any help with this will be appreciated because I'm stuck. It seems (from what I can tell) to be getting fuel fine. After all this happens the coil usually is pretty hot too."
