B
Brett Cobler
Guest
"I just removed my outdrive ye
"I just removed my outdrive yesterday to install a new lower shift cable. I have the new cable in, but I'm having a ton of trouble getting the drive back on the boat. Everything slides in fine until the first u-joint goes in and then it hangs. I've tried applying pressure and turning the u-joint, but nothing seems to work. It almost acts like the inner spline and the bearing are out of alignment, so the splines won't match up. Is this possible since nothing has changed since I removed the drive? If so, how can I get these back in alignment? If anyone has any tips for getting the drive to go back on, they would be greatly appreciated. Thanks"
