New to me NS5B year 1990.
Front op panel has choke, kill button(not emergency off switch) empty hole with rubber plug then a push button (missing rubber cover). When I push button gas leaks out,push again and it stops. The button leads to a fuel line that goes to a Y connector. One part of Y is this fuel line,other part leads to fuel filter then to carb. The leg leads to a manual shut off at the fuel tank. I have looked in parts manual but it does not show this button? What the heck is this button?
Cleaned carb but couldn't get screw out that holds float. Tried to start engine but it will only run on the fuel I spray into intake. I assume I need to take carb apart again and clean float valve.
thanks for any help
RBC
thanks for any help
RBC
