"In August I replaced the slav
"In August I replaced the slave solinoid, starter and battery. Took out once and ran well. Next time out after using for an hour I shut it off, upon trying to start it again it acted like the battery was going dead and wouldn't start. Brought it home and forgot about it. With a fully charged battery or with jumper cables to my truck, the engine cranks real slow like the battery needs a charge. I even used the jumper cables from ground on the battery to engine ground and plus on the battery to the starter. No change. It seems like something is binding or the starter is to small but it is the correct starter. I may just winterize and forget until next season as it's gettin cold in CT. The oil is okay as the symptoms happened when the boat was hot. Thanks for any input."
