I just bought a boat with a 75 mariner as a non runner (got it at the right price) was told that they thought the stator was the problem.
when I got it home I pulled the flywheel and found all of the magnets had came off and two were broken.
I removed the stator and it checked out pretty close to where it should be resistance wise so borrowed a flywheel from a friend who has quite a few spare parts and after fitting it spun the motor to check for a spark.
I was only getting a spark on No.1 cylinder so I changed the trigger wires on the switch box and managed to get a spark on each cylinder proving coils were OK and hopefully the switch box as well.
To me that pointed to the trigger but my friend told me it was unusual for the trigger to fail so I borrowed a stator from him and got exactly the same result unfortunately he doesn't have a spare trigger unit.
Now looking for some advice if there is anything else that could be causing the problem.
hopefully the parts I borrowed are compatible my flywheel 9007C2 borrowed 9007C3 my stator 398-9710A14 borrowed 398-9710A28
Thanks in advance
Cam
Thanks in advance
Cam
