Pat Carroll
I am about to install the third starter on my 1990 Johnson GT150 in the last year. I know for a fact that I am using the correct part number. What seems to be happening is the starter overheats and then fails. After trying today to start the motor for only half a minute or so the housing on the outside of the motor is too hot to touch. It acts like the battery doesn't have enough power to turn the motor over. It hesitates instead of spinning smoothly. I know my battery is good. I had it tested today and it showed to be overcharged with 855 CCA when it is rated at 800. This is the second time I have had this same problem in the last 6 months.
I wonder if I am ruining the starters by running the starter for too long on days when I have problems getting the motor started. Some days the motor starts and runs basically right off the trailer and other days it won't start at all. On days when I am having trouble getting the motor started how long should I try starting it before I give it a rest so I don't ruin another starter?
I am not sure why some days the motor starts and runs perfectly from the jump and other days I end up running the battery down and going home without fishing a lick. I follow the same starting procedure every time yet it seems that sometimes the motor floods out. Should I be doing something differently based on the air temperature? It is definitely harder to start on cold days.
